Ana içeriğe geç
Canon PowerShot SX280 HS Case Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX280 HS Case Replacement, Case: adım 1, 1 resimden 1.
    • Before taking apart your device ensure that you have:
    • Turned the camera off.
    • Removed the battery to reduce the risk of shock.
  2. Canon PowerShot SX280 HS Case Replacement: adım 2, 1 resimden 1.
    • Turn off the camera by pressing and holding the ON/OFF button that is located on the top of the camera.
    • Now that the camera is off, the battery can be removed.
    • Firmly place your finger on the battery door and slide to the right.
    • Once the door is open, a small orange button will be visible. Slide this button down to release the battery.
  3. Canon PowerShot SX280 HS Case Replacement: adım 4, 1 resimden 1.
    • Now you can begin to take the outer screws out. Removing these will allow you to remove the camera case. It will require a #00 Phillips Screwdriver.
  4. Canon PowerShot SX280 HS Case Replacement: adım 5, 1 resimden 1.
    • There are two screws in the left side of the camera, which are marked in the photo. Remove these screws first.
  5. Canon PowerShot SX280 HS Case Replacement: adım 6, 1 resimden 1.
    • There are two screws to remove on the right side of the camera as well, as marked in the photo. Remove these screws next.
  6. Canon PowerShot SX280 HS Case Replacement: adım 7, 1 resimden 1.
    • Finally, there are two screws on the bottom that need to be removed, which are marked in the photo.
  7. Canon PowerShot SX280 HS Case Replacement: adım 8, 2 resimden 1. Canon PowerShot SX280 HS Case Replacement: adım 8, 2 resimden 2.
    • Now that the outer screws are removed, you can take the case off.
    • Gently separate the case from the body of the camera. The camera case will separate into two pieces.
    • Do not leave the case off for too long, as dust could settle in to the camera and impair the its functionality.
  8. Canon PowerShot SX280 HS Case Replacement: adım 9, 1 resimden 1.
    • Now you can place a new camera case on the camera. As said in the step above, be wary of leaving the case off for too long, as this could damage key components in the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mason Boyd
228 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Miles Spring 2015 UMass Dartmouth, Team 1-5, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
I'd love to see a guide for disassembling the lens, to remove dust/lint inside.
Andrew Lamb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 800
