Ana içeriğe geç
Canon PowerShot SX50 HS Function Dial Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX50 HS Function Dial Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Function Dial Replacement: adım 2, 1 resimden 1.
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Function Dial Replacement, Rear Case: adım 3, 2 resimden 1. Canon PowerShot SX50 HS Function Dial Replacement, Rear Case: adım 3, 2 resimden 2.
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
  4. Canon PowerShot SX50 HS Function Dial Replacement: adım 4, 2 resimden 1. Canon PowerShot SX50 HS Function Dial Replacement: adım 4, 2 resimden 2.
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
  5. Canon PowerShot SX50 HS Function Dial Replacement: adım 5, 1 resimden 1.
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
  6. Canon PowerShot SX50 HS Function Dial Replacement: adım 6, 2 resimden 1. Canon PowerShot SX50 HS Function Dial Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
  7. Canon PowerShot SX50 HS Function Dial Replacement: adım 7, 3 resimden 1. Canon PowerShot SX50 HS Function Dial Replacement: adım 7, 3 resimden 2. Canon PowerShot SX50 HS Function Dial Replacement: adım 7, 3 resimden 3.
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
  8. Canon PowerShot SX50 HS Function Dial Replacement: adım 8, 3 resimden 1. Canon PowerShot SX50 HS Function Dial Replacement: adım 8, 3 resimden 2. Canon PowerShot SX50 HS Function Dial Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
  9. Canon PowerShot SX50 HS Function Dial Replacement: adım 9, 1 resimden 1.
    • Now you can completely separate the back encasement from the rest of the camera.
  10. Canon PowerShot SX50 HS Function Dial Replacement, Function Dial: adım 10, 1 resimden 1.
    • Remove the four Phillips #000 screws, length 3 mm, attaching the metal panel to the inside of the back encasement.
  11. Canon PowerShot SX50 HS Function Dial Replacement: adım 11, 2 resimden 1. Canon PowerShot SX50 HS Function Dial Replacement: adım 11, 2 resimden 2.
    • Take off the metal plate with your fingers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Remington Goodwin
250 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-7, Lancaster Spring 2015 Cal Poly, Team 12-7, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G7
5 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Interested to know where I can buy the switch/ribbon assembly for that function dial?
Liz Comery - Yanıt
I appreciated the clear instructions and photos. Couldn’t be any better. Now I would like to know where to purchase the dial assembly.
Rita McLachlan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 1,296
