Ana içeriğe geç
Canon PowerShot SX520 HS Lens Replacement
Neye ihtiyacın var
    1. Canon PowerShot SX520 HS Lens Replacement, Battery: adım 1, 1 resimden 1.
      • Using your fingers, slide the battery compartment door to the right until it unlocks.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX520 HS Lens Replacement: adım 2, 1 resimden 1.
      • Rotate the door along hinges to open.
      • Take out the battery with your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX520 HS Lens Replacement, Back Face: adım 3, 3 resimden 1. Canon PowerShot SX520 HS Lens Replacement, Back Face: adım 3, 3 resimden 2. Canon PowerShot SX520 HS Lens Replacement, Back Face: adım 3, 3 resimden 3.
      • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
      • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX520 HS Lens Replacement: adım 4, 1 resimden 1.
      • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot SX520 HS Lens Replacement: adım 5, 2 resimden 1. Canon PowerShot SX520 HS Lens Replacement: adım 5, 2 resimden 2.
      • Pull back the rubber facing to access the A/V and HDMI output compartment.
      • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot SX520 HS Lens Replacement: adım 6, 1 resimden 1.
      • Once all screws are removed, pull the back facing off with your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX520 HS Lens Replacement, LCD Screen: adım 7, 1 resimden 1.
      • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX520 HS Lens Replacement: adım 8, 1 resimden 1.
      • Carefully pop out the LCD screen with your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX520 HS Lens Replacement, Metal Plate: adım 9, 3 resimden 1. Canon PowerShot SX520 HS Lens Replacement, Metal Plate: adım 9, 3 resimden 2. Canon PowerShot SX520 HS Lens Replacement, Metal Plate: adım 9, 3 resimden 3.
      • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
      • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
      • After all 8 screws are removed, pull the metal plate out with your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot SX520 HS Lens Replacement, Lens: adım 10, 1 resimden 1.
      • Unlcip the large cable by pulling up on the metal part with your finger.
      • Slide out the 2 smaller cables with your fingers.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot SX520 HS Lens Replacement: adım 11, 1 resimden 1.
      • Lift up the lens by grabbing the sides with your fingers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Lisa Choe
460 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-4, Williams Fall 2015 Baylor, Team 4-4, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S4G4
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
guide is unfinished; dropping to the point of lens group extraction without going on further. I found it, useless.
SimoneGallina - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 49
Her zaman: 3,793
