Giriş
This guide will walk you through the necessary steps to replace either the motherboard or lens assembly from your Canon PowerShot SX60 HS.
The motherboard controls all aspects of the device and its operation. The lens assembly houses all the optics used to capture images.
Before starting this guide make sure to consult our troubleshooting page to ensure that this repair is necessary for your device.
This guide essentially requires you to completely disassemble the device, so there are lots of ribbons, electronics and optics that could break potentially damaging your device further.
Make sure to completely power off the device before starting this repair.
Neye ihtiyacın var
Make sure to power off the device before completing any more steps.
Remove the battery by releasing the orange clip in the battery compartment.
Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
Bu adımda kullanılan alet:Tweezers$4.99
Use the iFixit opening tool to pry off the back panel.
Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
Once the ribbon is unplugged, remove the back panel from the camera body.
Remove the sunshade located on the front of the lens by twisting it 90 degrees in either direction, then pull straight off the lens.
Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
Use the Phillips #00 screwdriver to remove the two 2mm #00 silver screws located under the viewfinder.
Remove the plastic housing around the viewfinder by using a black spudger or opening tool to unclip the 3 plastic clips on the sides of the viewfinder.
Remove the 4mm #00 Philips screw located on the top left corner beneath the front panel.
Remove the 5mm #00 Philips screw located on the top left corner beneath the front panel.
Remove the 5mm #00 Philips screw located on the top of the left side panel near the microphone connection.
Remove the 4mm #00 Philips screw located on the bottom left corner beneath the front panel.
Using a black spudger, unclip the orange wire ribbon on the lower left corner of the motherboard and then remove it using the nylon tipped tweezers.
The side panel is now free and can be removed by pulling the panel to the left.
Remove one silver 2mm #00 Philips screw on the front side located next the flash assembly.
Use the black spudger to unclip the ribbon on the top right corner and then remove it using the nylon tipped tweezers.
Remove one silver 2mm #00 Philips screw found underneath the ribbon.
Once the screw is removed, the top panel is completely detached from the device. To remove it, grab it by hand and gently pull it off the device.
Remove the four 2mm #00 Phillips head screws from the metal back plate.
Remove the 4mm #00 Phillips head screw from the top corner of the metal back plate.
Remove the four black 3.5mm #00 Phillips head screws holding the lens motor and motherboard to the metal back plate.
Remove the two silver 4mm #00 Phillips head screws holding the lens motor and motherboard to the metal back plate.
Use the black spudger to remove the 3 wire ribbon connections on the motherboard.
Remove one 2mm #00 Philips head screw from the bottom of the camera frame. This will free the lens and motherboard from the frame.
Gently separate the metal frame from the lens assembly just enough to reach the wire ribbon on the front side of the camera.
Use the rubber tipped tweezers to unplug the wire ribbon.
Remove the metal frame and slide the lens motor assembly out of the plastic frame.
