Ana içeriğe geç
Canon PowerShot SX60 HS Top Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX60 HS Top Cover Replacement, Back Panel: adım 1, 1 resimden 1.
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Top Cover Replacement: adım 2, 2 resimden 1. Canon PowerShot SX60 HS Top Cover Replacement: adım 2, 2 resimden 2.
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
    Check end punctuation here.
    Alex Watkins - Yanıt
  3. Canon PowerShot SX60 HS Top Cover Replacement: adım 3, 2 resimden 1. Canon PowerShot SX60 HS Top Cover Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Top Cover Replacement: adım 4, 2 resimden 1. Canon PowerShot SX60 HS Top Cover Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
    The first step is a little confusing to me—can you clarify what you mean? Also, be sure to check end punctuation on each step.
    On the third step, only the thin plastic ribbon comes out, the brown and gray plastic parts are the connector and will stay with the board, I pulled the gray plastic part and broke the connector.
    Antonio Xeira - Yanıt
  5. Canon PowerShot SX60 HS Top Cover Replacement, Front Panel: adım 5, 2 resimden 1. Canon PowerShot SX60 HS Top Cover Replacement, Front Panel: adım 5, 2 resimden 2.
    • Remove the sunshade located on the front of the lens by twisting it 90 degrees in either direction, then pull straight off the lens.
    Should this be two steps? Do you have any images of you removing the lens?
  6. Canon PowerShot SX60 HS Top Cover Replacement: adım 6, 3 resimden 1. Canon PowerShot SX60 HS Top Cover Replacement: adım 6, 3 resimden 2. Canon PowerShot SX60 HS Top Cover Replacement: adım 6, 3 resimden 3.
    • Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
    • Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
    • Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
    • Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
  7. Canon PowerShot SX60 HS Top Cover Replacement: adım 7, 1 resimden 1.
    • Remove the front cover by pulling along the lens housing while holding the body of the camera.
    This is a great example of the final shot that I think some of your other guides need, which iFixit was referring to in the feedback.
  8. Canon PowerShot SX60 HS Top Cover Replacement, Top Cover: adım 8, 1 resimden 1.
    • Remove one silver 2mm #00 Philips screw on the front side located next the flash assembly.
  9. Canon PowerShot SX60 HS Top Cover Replacement: adım 9, 3 resimden 1. Canon PowerShot SX60 HS Top Cover Replacement: adım 9, 3 resimden 2. Canon PowerShot SX60 HS Top Cover Replacement: adım 9, 3 resimden 3.
    • Use the black spudger to unclip the ribbon on the top right corner and then remove it using the nylon tipped tweezers.
    • Remove one silver 2mm #00 Philips screw found underneath the ribbon.
    • Once the screw is removed, the top panel is completely detached from the device. To remove it, grab it by hand and gently pull it off the device.
    Check capitalization here, and see specifically the lack of clarity in the orange bullet. How will the top cover come free—does the user need to lift it off? will it fall off? Etc.
Sonuç
1Rehber Yorum
I have a Canon SX610 HS Powershot and it has given me years of good service. Today, I powered it on but could not power it off again without removing the battery. Please help on this problem. Thank you and regards, Ivan (South Africa)
radnet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 604
