Ana içeriğe geç
Canon PowerShot SX60 HS Viewfinder Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX60 HS Viewfinder Replacement, Back Panel: adım 1, 1 resimden 1.
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Viewfinder Replacement: adım 2, 2 resimden 1. Canon PowerShot SX60 HS Viewfinder Replacement: adım 2, 2 resimden 2.
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Viewfinder Replacement: adım 3, 2 resimden 1. Canon PowerShot SX60 HS Viewfinder Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Viewfinder Replacement: adım 4, 2 resimden 1. Canon PowerShot SX60 HS Viewfinder Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Viewfinder Replacement, Viewfinder: adım 5, 2 resimden 1. Canon PowerShot SX60 HS Viewfinder Replacement, Viewfinder: adım 5, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the two 2mm #00 silver screws located under the viewfinder.
    • Don't pull the viewfinder all the way out because there is still a wire ribbon attached.
    • Remove the plastic housing around the viewfinder by using a black spudger or opening tool to unclip the 3 plastic clips on the sides of the viewfinder.
  6. Canon PowerShot SX60 HS Viewfinder Replacement: adım 6, 2 resimden 1. Canon PowerShot SX60 HS Viewfinder Replacement: adım 6, 2 resimden 2.
    • Unclip the ribbon from the ZIF connector on the viewfinder.
    • Pull out the viewfinder.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 862
