Giriş
Canon PowerShot SX600 HS camera, can have a broken or damaged screen/LCD. The screen can be noted to have cracks or the LCD does not allow the screen to display, either or calls for a replacement of the display screen. Use this guide when replacing the display screen or LCD for your camera.
Neye ihtiyacın var
To remove the battery, locate the battery cover on the bottom of the camera.
Using your thumb, press down on the cover and slide it outwards.
Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
7 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I did all this with a new LCD. After reassemble the lens has extended out but camera does not turn on. Should I take it apart again and start from beginning. Is there a connector not in place correctly that will cause this to happen?
