Ana içeriğe geç
Canon PowerShot SX600 HS Lens Piece Replacement
Neye ihtiyacın var
  1. Canon PowerShot SX600 HS Lens Piece Replacement, Battery: adım 1, 1 resimden 1.
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Lens Piece Replacement: adım 2, 1 resimden 1.
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Lens Piece Replacement: adım 3, 2 resimden 1. Canon PowerShot SX600 HS Lens Piece Replacement: adım 3, 2 resimden 2.
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Lens Piece Replacement, Power and Shutter Buttons: adım 4, 1 resimden 1.
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Lens Piece Replacement: adım 5, 1 resimden 1.
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Lens Piece Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Lens Piece Replacement: adım 7, 2 resimden 1. Canon PowerShot SX600 HS Lens Piece Replacement: adım 7, 2 resimden 2.
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Lens Piece Replacement: adım 8, 1 resimden 1.
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
  9. Canon PowerShot SX600 HS Lens Piece Replacement, Display Screen: adım 9, 2 resimden 1. Canon PowerShot SX600 HS Lens Piece Replacement, Display Screen: adım 9, 2 resimden 2.
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
  10. Canon PowerShot SX600 HS Lens Piece Replacement: adım 10, 1 resimden 1.
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
  11. Canon PowerShot SX600 HS Lens Piece Replacement: adım 11, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
  12. Canon PowerShot SX600 HS Lens Piece Replacement: adım 12, 1 resimden 1.
    • Gently lift the protector from the frame.
  13. Canon PowerShot SX600 HS Lens Piece Replacement: adım 13, 1 resimden 1.
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
  14. Canon PowerShot SX600 HS Lens Piece Replacement, Flash Assembly: adım 14, 1 resimden 1.
    • Unplug the assembly from the main no-fuss connector.
  15. Canon PowerShot SX600 HS Lens Piece Replacement: adım 15, 1 resimden 1.
    • Unplug the assembly from its flat-top connection.
  16. Canon PowerShot SX600 HS Lens Piece Replacement: adım 16, 1 resimden 1.
    • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
  17. Canon PowerShot SX600 HS Lens Piece Replacement: adım 17, 1 resimden 1.
    • Gently lift the assembly out of its place.
  18. Canon PowerShot SX600 HS Lens Piece Replacement, Lens Piece: adım 18, 1 resimden 1.
    • Remove the 4 remaining 4mm screws in the frame with a Phillips #000 screwdriver.
  19. Canon PowerShot SX600 HS Lens Piece Replacement: adım 19, 2 resimden 1. Canon PowerShot SX600 HS Lens Piece Replacement: adım 19, 2 resimden 2.
    • Gently remove the frame. (Make sure to have a firm hold on the rest of the camera at this point)
    • The camera will be loose after this point. Be sure to have a firm hold on it.
  20. Canon PowerShot SX600 HS Lens Piece Replacement: adım 20, 1 resimden 1.
    • Unplug the ZIF connection between the lens to the main processor.
  21. Canon PowerShot SX600 HS Lens Piece Replacement: adım 21, 1 resimden 1.
    • Detach the flat-top connection.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Scott Childress
752 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G4, Lacy Spring 2017 USF Tampa, Team S6-G4, Lacy Spring 2017 üyesi
USFT-LACY-S17S6G4
3 Üyeler
9 adet Kılavuz yazıldı
5Kılavuz Yorumları
Does anyone know where can I get the internal connections for the focus motor? I mistakenly tore a cable.
Misham Faith. S - Yanıt
I completed the disassembly. I did not replace zoom lens assembly however. I could not find a new zoom lens except some offers for old cameras that I could disassemble. In the meantime I was checking the Canon SX600 HS manual and I think I missed some procedures to try as to why camera was not taking pictures. So I decided to re-assemble my camera. BUT AT STEPS 11 AND 12 I GOT STUCK. I have not been able to re-connect the ribbon. At one point I had it re-connected but could not put the frame piece back without dis-connecting the ribbon again. So I dis-connected ribbon. But now I cannot get the ribbon back into connector no matter how hard I try. Is there anyone available with the necessary skills and microscopic tools to see what micro-damage I did to the connector? I live in San Diego. HELP!!
Michael Chilcott - Yanıt
To continue: I got up in the middle of the night to give the ribbon another try. I forced it and sure enough—I tore the ribbon. Ribbon problem now behind me. Now on to Plan B. I need another frame/ribbon combo. The tiny frame is the one on the back of the camera next to the screen, which is underneath all the buttons. It registers all the fingering. Next time, I am going to cut a bigger notch on the side of the frame so I can get more length of ribbon to reach the connector underneath—if I have to. I notice up above that Misham Faith. S also tore a ribbon. Did you ever resolve that problem, Misham?
i also have the same problem with ribbon. step 11 on re-assembling is impossible to do
Umair Afridi - Yanıt
To put that back together, you have to take the piece of circuitry that the buttons are on off of the metal piece. The metal frame has about 4 tiny tabs sticking up that make it easy to pop the button assembly off. After you get that apart, plug the ribbon in, and then screw the metal frame in place. After that flip the button assembly un over the metal frame and pop it in place.
Melvin Jr. -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 37
Her zaman: 2,784
