Giriş
If your camera is not quite functioning correctly, it may be the processor has become faulty. We'll show you how to fix it.
Neye ihtiyacın var
To remove the battery, locate the battery cover on the bottom of the camera.
Using your thumb, press down on the cover and slide it outwards.
Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
Remove the 4 remaining 4mm screws in the frame with a Phillips #000 screwdriver.
Bir Yorum
Note re Step 13: the cable has a 'click' type lock (you can see it as a narrow brown plastic strip on Step 12 and 13 pics). This lock can just about be disengaged with care before extracting the cable, I didn't, I just released it with tweezers as shown, and it didn't cause a problem. However, reversing Step 11 is very very difficult and you MUST have the click lock thing open before you begin (it's easy to see and understand when the switch plate is off , look at Step 12). You can then (just about!) re-insert the cable, and through a hole in the metal frame, just kind of below where the shutter button lies, flip the lock back down to hold the cable (use a tiny screwdriver or similar). It took me an hour to get the cable back in...so good luck with this part!
