Giriş
If you have broken the back cover to your camera or it is worn out this guide will show you how to replace it.
Neye ihtiyacın var
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
