Giriş
This guide will show you how to replace a broken or malfunctioning LCD display.
Neye ihtiyacın var
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
Use a JIS 000 screwdriver and remove the 3.0mm screw from the bottom housing.
Bir başkası bu kılavuzu tamamladı.
