Ana içeriğe geç
Canon Powershot A3300 IS LCD Display Replacement
Neye ihtiyacın var
  1. Canon Powershot A3300 IS LCD Display Replacement, Back Cover: adım 1, 3 resimden 1. Canon Powershot A3300 IS LCD Display Replacement, Back Cover: adım 1, 3 resimden 2. Canon Powershot A3300 IS LCD Display Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS LCD Display Replacement: adım 2, 2 resimden 1. Canon Powershot A3300 IS LCD Display Replacement: adım 2, 2 resimden 2.
    • Pull off the back cover.
  3. Canon Powershot A3300 IS LCD Display Replacement, Front Cover: adım 3, 2 resimden 1. Canon Powershot A3300 IS LCD Display Replacement, Front Cover: adım 3, 2 resimden 2.
    • Pull the front cover off.
  4. Canon Powershot A3300 IS LCD Display Replacement, LCD Display: adım 4, 1 resimden 1.
    • Use a JIS 000 screwdriver and remove the 3.0mm screw from the bottom housing.
  5. Canon Powershot A3300 IS LCD Display Replacement: adım 5, 1 resimden 1.
    • Gently lift the LCD screen off the back of the camera.
  6. Canon Powershot A3300 IS LCD Display Replacement: adım 6, 1 resimden 1.
    • Use tweezers to pull out the circled brown flat flexible wire from its connection.
  7. Canon Powershot A3300 IS LCD Display Replacement: adım 7, 2 resimden 1. Canon Powershot A3300 IS LCD Display Replacement: adım 7, 2 resimden 2.
    • Use a spudger to reach under the connecting wire.
    • Gently slide the spudger under the wire and lift the wire off the connection.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kenny Chui
122 İtibar
1 Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S2-G7, Weedon Fall 2017 UC Santa Barbara, Team S2-G7, Weedon Fall 2017 üyesi
UCSB-WEEDON-F17S2G7
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 596
