Ana içeriğe geç
Canon Powershot A3300 IS Motherboard Replacement
Neye ihtiyacın var
  1. Canon Powershot A3300 IS Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Canon Powershot A3300 IS Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Canon Powershot A3300 IS Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS Motherboard Replacement: adım 2, 2 resimden 1. Canon Powershot A3300 IS Motherboard Replacement: adım 2, 2 resimden 2.
    • Pull off the back cover.
  3. Canon Powershot A3300 IS Motherboard Replacement, Front Cover: adım 3, 2 resimden 1. Canon Powershot A3300 IS Motherboard Replacement, Front Cover: adım 3, 2 resimden 2.
    • Pull the front cover off.
  4. Canon Powershot A3300 IS Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Canon Powershot A3300 IS Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the black cover to expose the motherboard.
  5. Canon Powershot A3300 IS Motherboard Replacement: adım 5, 2 resimden 1. Canon Powershot A3300 IS Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the shutter button located at the top left of the camera.
    • This will expose the screws that need to be removed.
  6. Canon Powershot A3300 IS Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a JIS 000 screwdriver, remove the 1.2mm screw at the top left of the motherboard.
  7. Canon Powershot A3300 IS Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the 1.6mm screw at the top of the camera.
  8. Canon Powershot A3300 IS Motherboard Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to pull out brown flat flexible wires from their connection.
    • Remember to gently wiggle the wires from the connection since they are very fragile connectors.
  9. Canon Powershot A3300 IS Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the last 1.2mm screw to pull out the motherboard.
    • The motherboard should freely separate from the housing.
  10. Canon Powershot A3300 IS Motherboard Replacement: adım 10, 3 resimden 1. Canon Powershot A3300 IS Motherboard Replacement: adım 10, 3 resimden 2. Canon Powershot A3300 IS Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove motherboard and replace with a new one.
Sonuç
Phillip Chen
440 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S2-G7, Weedon Fall 2017 UC Santa Barbara, Team S2-G7, Weedon Fall 2017 üyesi
UCSB-WEEDON-F17S2G7
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 471
