Ana içeriğe geç
Canon Powershot A610 Camera Housing Replacement
Neye ihtiyacın var
  1. Canon Powershot A610 Camera Housing Replacement, Batteries: adım 1, 2 resimden 1. Canon Powershot A610 Camera Housing Replacement, Batteries: adım 1, 2 resimden 2.
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Camera Housing Replacement: adım 2, 1 resimden 1.
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Camera Housing Replacement, Camera Housing: adım 3, 3 resimden 1. Canon Powershot A610 Camera Housing Replacement, Camera Housing: adım 3, 3 resimden 2. Canon Powershot A610 Camera Housing Replacement, Camera Housing: adım 3, 3 resimden 3.
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Camera Housing Replacement: adım 4, 1 resimden 1.
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Camera Housing Replacement: adım 5, 1 resimden 1.
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Camera Housing Replacement: adım 6, 2 resimden 1. Canon Powershot A610 Camera Housing Replacement: adım 6, 2 resimden 2.
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Camera Housing Replacement: adım 7, 1 resimden 1.
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Camera Housing Replacement: adım 8, 2 resimden 1. Canon Powershot A610 Camera Housing Replacement: adım 8, 2 resimden 2.
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Camera Housing Replacement: adım 9, 2 resimden 1. Canon Powershot A610 Camera Housing Replacement: adım 9, 2 resimden 2.
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Camera Housing Replacement: adım 10, 3 resimden 1. Canon Powershot A610 Camera Housing Replacement: adım 10, 3 resimden 2. Canon Powershot A610 Camera Housing Replacement: adım 10, 3 resimden 3.
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Matthew Ramirez
625 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-26, Maness Winter 2011 Cal Poly, Team 11-26, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G26
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 9,311
