Ana içeriğe geç
Canon Powershot A70 Button Flex Assembly Replacement
Neye ihtiyacın var
  1. Canon Powershot A70 Button Flex Assembly Replacement, Shutter/Speaker Panel: adım 1, 1 resimden 1.
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Button Flex Assembly Replacement: adım 2, 2 resimden 1. Canon Powershot A70 Button Flex Assembly Replacement: adım 2, 2 resimden 2.
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Canon Powershot A70 Button Flex Assembly Replacement, Rear Exterior Panel: adım 3, 1 resimden 1.
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  4. Canon Powershot A70 Button Flex Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  5. Canon Powershot A70 Button Flex Assembly Replacement: adım 5, 3 resimden 1. Canon Powershot A70 Button Flex Assembly Replacement: adım 5, 3 resimden 2. Canon Powershot A70 Button Flex Assembly Replacement: adım 5, 3 resimden 3.
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  6. Canon Powershot A70 Button Flex Assembly Replacement: adım 6, 2 resimden 1. Canon Powershot A70 Button Flex Assembly Replacement: adım 6, 2 resimden 2.
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  7. Canon Powershot A70 Button Flex Assembly Replacement: adım 7, 1 resimden 1.
    • The interior of the camera should look like this.
  8. Canon Powershot A70 Button Flex Assembly Replacement, Front Exterior Panel: adım 8, 1 resimden 1.
    • Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
  9. Canon Powershot A70 Button Flex Assembly Replacement: adım 9, 2 resimden 1. Canon Powershot A70 Button Flex Assembly Replacement: adım 9, 2 resimden 2.
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
  10. Canon Powershot A70 Button Flex Assembly Replacement, Viewfinder: adım 10, 1 resimden 1.
    • After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
    • Three screws hold the viewfinder in place: two on the top and one on the lens side of the camera.
    • First, remove the screw in the bent corner of the viewfinder with a Phillips #00 screwdriver.
  11. Canon Powershot A70 Button Flex Assembly Replacement: adım 11, 1 resimden 1.
    • Remove the second screw directly across from the bent corner.
    • It may be hidden in the space under the orange circuitry with a Phillips #00 screwdriver.
  12. Canon Powershot A70 Button Flex Assembly Replacement: adım 12, 1 resimden 1.
    • Remove the final screw directly under the left side of the viewfinder (on the lens side) with a Phillips #00 screwdriver.
  13. Canon Powershot A70 Button Flex Assembly Replacement: adım 13, 1 resimden 1.
    • After removing the three screws, the only thing still holding the viewfinder in place is a small plastic peg.
    • Remove the viewfinder with a firm pull directly upwards.
  14. Canon Powershot A70 Button Flex Assembly Replacement, Speakers: adım 14, 1 resimden 1.
    • Remove the two clearly visible screws from the control dial with a Phillips #00 screwdriver.
    • Remove the dial—it should come off easily.
  15. Canon Powershot A70 Button Flex Assembly Replacement: adım 15, 2 resimden 1. Canon Powershot A70 Button Flex Assembly Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • With tweezers, carefully unplug the two small wires from the green plug.
    • Carefully replace the broken speaker/shutter panel with a new one.
  16. Canon Powershot A70 Button Flex Assembly Replacement: adım 16, 1 resimden 1.
    • The removed panel should look like this.
  17. Canon Powershot A70 Button Flex Assembly Replacement, Button Flex Assembly: adım 17, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the one visible screw that attaches the flex assembly to the back of the camera.
  18. Canon Powershot A70 Button Flex Assembly Replacement: adım 18, 2 resimden 1. Canon Powershot A70 Button Flex Assembly Replacement: adım 18, 2 resimden 2.
    • Starting with the bottom-left corner (below the screen), lift the flex assembly away from the camera chassis.
  19. Canon Powershot A70 Button Flex Assembly Replacement: adım 19, 1 resimden 1.
    • Use your finger to release the small metal tab that attaches the flex assembly to the upper-right corner of the camera.
    • The tab is very small and may be hard to see.
  20. Canon Powershot A70 Button Flex Assembly Replacement: adım 20, 1 resimden 1.
    • Disconnect the black connector by lifting it up.
    • Potential for device damage: You may damage the flex assembly if you forcibly remove it without disconnecting the connector.
  21. Canon Powershot A70 Button Flex Assembly Replacement: adım 21, 1 resimden 1.
    • Gently pull the rest of the flex assembly away from the camera body until you reach the last connector.
  22. Canon Powershot A70 Button Flex Assembly Replacement: adım 22, 2 resimden 1. Canon Powershot A70 Button Flex Assembly Replacement: adım 22, 2 resimden 2.
    • Hold the flex assembly gently but firmly, and pull it out of the connection with two fingers.
    • Be sure to pull straight up, not at an angle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian
102 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G40
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 6,388
