Ana içeriğe geç
Canon Powershot A70 Rear Exterior Panel Replacement
Neye ihtiyacın var
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: adım 1, 1 resimden 1.
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: adım 2, 1 resimden 1.
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: adım 3, 3 resimden 1. Canon Powershot A70 Rear Exterior Panel Replacement: adım 3, 3 resimden 2. Canon Powershot A70 Rear Exterior Panel Replacement: adım 3, 3 resimden 3.
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: adım 4, 2 resimden 1. Canon Powershot A70 Rear Exterior Panel Replacement: adım 4, 2 resimden 2.
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: adım 5, 1 resimden 1.
    • The interior of the camera should look like this.
Sonuç
Shalan Ertis
83 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G40
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 3,313
