Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Canon Powershot A70 Rear Exterior Panel Replacement
Neye ihtiyacın var
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: adım 1, 1 resimden 1.
    • Unscrew the three small screws on the bottom of the camera.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: adım 2, 1 resimden 1.
    • Remove the screw in the CF compartment.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: adım 3, 3 resimden 1. Canon Powershot A70 Rear Exterior Panel Replacement: adım 3, 3 resimden 2. Canon Powershot A70 Rear Exterior Panel Replacement: adım 3, 3 resimden 3.
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with the IFIXIT opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: adım 4, 2 resimden 1. Canon Powershot A70 Rear Exterior Panel Replacement: adım 4, 2 resimden 2.
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: adım 5, 1 resimden 1.
    • The interior of the camera should look like this.
Sonuç
Shalan Ertis
68 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G40
5 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 3,239
