Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Have you ever had your shutter button get stuck in the middle of taking pictures? Use this guide to get it back in place.
Neye ihtiyacın var
Carefully insert the tip of one end of the tweezers in the space between the shutter button and the zoom dial. Gently try and get the tip under the button and slowly lift.
If the initial shutter button dislodge does not work, we have to disassemble the camera.
On the bottom of the camera, use your thumb and push the battery lock up to open. The battery compartment door should then spring open and batteries will slide out.
Remove the six 4 mm phillips head screws that are found on both the sides and bottom of the camera with the Phillips #00 Precision Screwdriver.
Carefully lift and turnover the LCD Screen so that you are able to see the motherboard.
Carefully disconnect the LCD Screen ribbon cable away from its ZIF connector with your thumb and index finger. You must make sure to have your thumb and index finger cover as much of the ribbon's width and as close to the ZIF connector as possible without touching the motherboard while pulling the ribbon out. line.
