Ana içeriğe geç
Canon Powershot ELPH 100 HS LCD Display Replacement
Neye ihtiyacın var
  1. Canon Powershot ELPH 100 HS LCD Display Replacement, Battery: adım 1, 3 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement, Battery: adım 1, 3 resimden 2. Canon Powershot ELPH 100 HS LCD Display Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 2, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 2, 2 resimden 2.
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS LCD Display Replacement, Memory Card: adım 3, 3 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement, Memory Card: adım 3, 3 resimden 2. Canon Powershot ELPH 100 HS LCD Display Replacement, Memory Card: adım 3, 3 resimden 3.
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
  4. Canon Powershot ELPH 100 HS LCD Display Replacement, Outer Case: adım 4, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  5. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 5, 1 resimden 1.
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  6. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 6, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 6, 2 resimden 2.
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  7. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 7, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 7, 2 resimden 2.
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  8. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 8, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 8, 2 resimden 2.
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  9. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 9, 1 resimden 1.
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  10. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 10, 3 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 10, 3 resimden 2. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 10, 3 resimden 3.
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
  11. Canon Powershot ELPH 100 HS LCD Display Replacement, LCD Display: adım 11, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement, LCD Display: adım 11, 2 resimden 2.
    • Remove the 3.1mm screw on the top-right side of the LCD display screen.
  12. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 12, 1 resimden 1.
    • Use the spudger to carefully separate the screen from the frame.
  13. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 13, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 13, 2 resimden 2.
    • Use the spudger to lift up the latch on the zero insertion force connector (ZIF).
    • Slide the now free ribbon cable from the connector.
  14. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 14, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 14, 2 resimden 2.
    • Holding the display screen, gently pull the ribbon cable out through the frame of the camera.
  15. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 15, 2 resimden 1. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully remove the ribbon cable from the connector shown.
  16. Canon Powershot ELPH 100 HS LCD Display Replacement: adım 16, 1 resimden 1.
    • The display screen should now be free.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jacob
570 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G10
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 66
Her zaman: 3,448
