Ana içeriğe geç
Canon Powershot ELPH 100 HS Memory Card Replacement
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: adım 1, 3 resimden 1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: adım 1, 3 resimden 2. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: adım 2, 2 resimden 1. Canon Powershot ELPH 100 HS Memory Card Replacement: adım 2, 2 resimden 2.
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: adım 3, 3 resimden 1. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: adım 3, 3 resimden 2. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: adım 3, 3 resimden 3.
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
Sonuç
Lillia
255 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G10
2 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
my internal card reader hardware is not functional
can i replace it somehow
s l - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 37
Her zaman: 1,028
