Ana içeriğe geç
Canon Powershot ELPH 100 HS Outer Case Replacement
Neye ihtiyacın var
  1. Canon Powershot ELPH 100 HS Outer Case Replacement, Outer Case: adım 1, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  2. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 2, 1 resimden 1.
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  3. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 3, 2 resimden 1. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 3, 2 resimden 2.
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  4. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 4, 2 resimden 1. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 4, 2 resimden 2.
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  5. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 5, 2 resimden 1. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 5, 2 resimden 2.
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  6. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 6, 1 resimden 1.
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  7. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 7, 3 resimden 1. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 7, 3 resimden 2. Canon Powershot ELPH 100 HS Outer Case Replacement: adım 7, 3 resimden 3.
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jacob
570 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G10
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 1,675
