Ana içeriğe geç
Canon Powershot Pro1 Flash Replacement
Neye ihtiyacın var
  1. Canon Powershot Pro1 Flash Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Flash Replacement: adım 2, 1 resimden 1.
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Flash Replacement: adım 3, 1 resimden 1.
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Flash Replacement: adım 4, 1 resimden 1.
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Flash Replacement, Flash: adım 5, 2 resimden 1. Canon Powershot Pro1 Flash Replacement, Flash: adım 5, 2 resimden 2.
    • Remove the 25.4 mm Phillips #0 flash screw. The screw is near the flash.
    • Be careful not to damage the screw.
  6. Canon Powershot Pro1 Flash Replacement: adım 6, 1 resimden 1.
    • Locate the small points on both sides of the lens.
    • Pry the lens housing using the black nylon spudger so that it is lifted out of these points.
    • Don't use a screwdriver as a prying tool, this could cause damage.
  7. Canon Powershot Pro1 Flash Replacement: adım 7, 1 resimden 1.
    • Use the plastic spudger to remove the upper portion of the flash housing.
  8. Canon Powershot Pro1 Flash Replacement: adım 8, 3 resimden 1. Canon Powershot Pro1 Flash Replacement: adım 8, 3 resimden 2. Canon Powershot Pro1 Flash Replacement: adım 8, 3 resimden 3.
    • Use the nylon spudger to dislodge the flash bulb and capacitor from the housing.
    • Don't use a screwdriver as prying tool, this could cause damage.
  9. Canon Powershot Pro1 Flash Replacement: adım 9, 1 resimden 1.
    • Cut the flash and capacitor cables with a wire cutter.
Sonuç
Seana Meegan
654 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 678
