Ana içeriğe geç
Canon Powershot Pro1 Lens Replacement
Neye ihtiyacın var
    1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: adım 1, 2 resimden 1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: adım 1, 2 resimden 2.
      • Have the lens of the camera facing upwards.
      • Find the red plastic ring.
      • Look for two small opening above the red plastic ring.
      • Reference to the left of the picture and you will see the orange square.
      FixBot'a Sor
      Yorum Ekle
    2. Canon Powershot Pro1 Lens Replacement: adım 2, 3 resimden 1. Canon Powershot Pro1 Lens Replacement: adım 2, 3 resimden 2. Canon Powershot Pro1 Lens Replacement: adım 2, 3 resimden 3.
      • Remove the plastic ring that has a red strip.
      • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
      FixBot'a Sor
      Yorum Ekle
    3. Canon Powershot Pro1 Lens Replacement: adım 3, 3 resimden 1. Canon Powershot Pro1 Lens Replacement: adım 3, 3 resimden 2. Canon Powershot Pro1 Lens Replacement: adım 3, 3 resimden 3.
      • Place the camera on its back with the lens facing upwards as shown in the image
      • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
      • Remove the screw by turning the Philip driver counterclockwise.
      • By removing the screw, you will be able to remove the cover lens.
      FixBot'a Sor
      Yorum Ekle
    4. Canon Powershot Pro1 Lens Replacement: adım 4, 1 resimden 1.
      • Use the nylon spudger to remove the ring holding the lens in place.
      • Pull gently until the lens ring snaps off.
      FixBot'a Sor
      Yorum Ekle
    5. Canon Powershot Pro1 Lens Replacement: adım 5, 1 resimden 1.
      • Refer to the left-hand pictere to see what the len's ring looks like.
      FixBot'a Sor
      Yorum Ekle
    6. Canon Powershot Pro1 Lens Replacement: adım 6, 3 resimden 1. Canon Powershot Pro1 Lens Replacement: adım 6, 3 resimden 2. Canon Powershot Pro1 Lens Replacement: adım 6, 3 resimden 3.
      • Take out the lens once the plastic ring is removed
      • Hold the outer layer of the lens to not create smudges on it.
      • Replace the lens and follow the instruction in reversed order to reassemble the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Seana Meegan
677 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 64
Her zaman: 4,038
