Ana içeriğe geç
Canon Powershot Pro1 Motherboard Replacement
Neye ihtiyacın var
  1. Canon Powershot Pro1 Motherboard  Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Motherboard  Replacement: adım 2, 1 resimden 1.
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Motherboard  Replacement: adım 3, 1 resimden 1.
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Motherboard  Replacement: adım 4, 1 resimden 1.
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: adım 5, 3 resimden 1. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: adım 5, 3 resimden 2. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: adım 5, 3 resimden 3.
    • Open the screen to access the underside of the camera.
  6. Canon Powershot Pro1 Motherboard  Replacement: adım 6, 3 resimden 1. Canon Powershot Pro1 Motherboard  Replacement: adım 6, 3 resimden 2. Canon Powershot Pro1 Motherboard  Replacement: adım 6, 3 resimden 3.
    • Using the Phillips #000 screwdriver:
    • Remove two 1.00 mm screws under the viewfinder.
    • Remove one screw in the battery compartment.
    • Remove five screws on the bottom of the camera.
    • Remove one screw on the left side of the camera (opposite the battery compartment).
  7. Canon Powershot Pro1 Motherboard  Replacement: adım 7, 3 resimden 1. Canon Powershot Pro1 Motherboard  Replacement: adım 7, 3 resimden 2. Canon Powershot Pro1 Motherboard  Replacement: adım 7, 3 resimden 3.
    • Completely detach the cover from the motherboard.
    • Lift the inside cover to reveal the motherboard.
    • Detach the bottom right ribbon cable from the motherboard.
  8. Canon Powershot Pro1 Motherboard  Replacement: adım 8, 2 resimden 1. Canon Powershot Pro1 Motherboard  Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Lift up the gold insulation cover to reveal the motherboard.
    • Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
  9. Canon Powershot Pro1 Motherboard  Replacement: adım 9, 3 resimden 1. Canon Powershot Pro1 Motherboard  Replacement: adım 9, 3 resimden 2. Canon Powershot Pro1 Motherboard  Replacement: adım 9, 3 resimden 3.
    • Once detached from all connectors and ribbon cables, remove the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Seana Meegan
677 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,001
