Ana içeriğe geç
Canon Powershot S110 Option Dial Replacement
Neye ihtiyacın var
  1. Canon Powershot S110 Option Dial Replacement, Option Dial: adım 1, 2 resimden 1. Canon Powershot S110 Option Dial Replacement, Option Dial: adım 1, 2 resimden 2.
    • Remove the battery by sliding open the battery cover on the bottom of the camera.
    • The battery must be removed to avoid shorting out any part of the camera.
  2. Canon Powershot S110 Option Dial Replacement: adım 2, 3 resimden 1. Canon Powershot S110 Option Dial Replacement: adım 2, 3 resimden 2. Canon Powershot S110 Option Dial Replacement: adım 2, 3 resimden 3.
    • Remove the six screws by using a small Phillips head screwdriver.
    • Remove the two screws on the side of the camera on either side of the HDMI input panel.
    • Remove the two screws on the opposite side of the camera.
    • Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
  3. Canon Powershot S110 Option Dial Replacement: adım 3, 1 resimden 1.
    • Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
    • Once all of the clips around the plastic cover are released, the cover will lift off.
  4. Canon Powershot S110 Option Dial Replacement: adım 4, 2 resimden 1. Canon Powershot S110 Option Dial Replacement: adım 4, 2 resimden 2.
    • Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
    • Remove the screw holding down the lens cover.
    • Remove the screw located near the option dial next to the USB connections.
  5. Canon Powershot S110 Option Dial Replacement: adım 5, 1 resimden 1.
    • Carefully lift the top panel of the camera by using a prying tool.
  6. Canon Powershot S110 Option Dial Replacement: adım 6, 1 resimden 1.
    • Remove the screw at the center of the option dial by using a Phillips head screwdriver.
  7. Canon Powershot S110 Option Dial Replacement: adım 7, 2 resimden 1. Canon Powershot S110 Option Dial Replacement: adım 7, 2 resimden 2.
    • Remove the underlying component that was attached to the now-removed screw by using a prying tool.
    • Remove the dial on the opposite side of the part using a prying tool.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
akac92
298 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-2, Liner SU 2015 UW Tacoma, Team 1-2, Liner SU 2015 üyesi
UWT-LINER-SU15S1G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,190
