Ana içeriğe geç
Canon Powershot S200 Motherboard Replacement
Neye ihtiyacın var
  1. Canon Powershot S200 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Canon Powershot S200 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: adım 2, 2 resimden 1. Canon Powershot S200 Motherboard Replacement: adım 2, 2 resimden 2.
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: adım 5, 1 resimden 1.
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: adım 9, 1 resimden 1.
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: adım 10, 2 resimden 1. Canon Powershot S200 Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: adım 11, 2 resimden 1. Canon Powershot S200 Motherboard Replacement: adım 11, 2 resimden 2.
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: adım 15, 2 resimden 1. Canon Powershot S200 Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the motherboard from the main frame of the camera body.
Sonuç
Orlando Zuniga
11 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 20-70, Walters Spring 2011 Cal Poly, Team 20-70, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G70
5 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 22
Her zaman: 1,947
