Giriş
Many companies sell only LCD screens, not complete screen assemblies. When replacing your broken LCD screen, it may be necessary to tear down the screen even further.
Parçalar
Hiçbir parçaya gerek yok.
In preparation for disassembly, the battery and SD Card need to be removed from the camera. You can access both the battery and the SD card through the door on the bottom of the camera.
  • In preparation for disassembly, the battery and SD Card need to be removed from the camera. You can access both the battery and the SD card through the door on the bottom of the camera.
Yorum Ekle
While being careful to remember the original location of each screw, remove the three 0.15 inch screws on the underside of the camera.
  • While being careful to remember the original location of each screw, remove the three 0.15 inch screws on the underside of the camera.
  • Each of the screws is slightly different, so it is important that you note the original location of each screw.
Yorum Ekle
Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches. Remove both screws, then carefully lift the side panel off. Underneath the side panel, there is a .07 inch screw. Remove it.
  • Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches.
  • Remove both screws, then carefully lift the side panel off.
  • Underneath the side panel, there is a .07 inch screw. Remove it.
Yorum Ekle
On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera. On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera. On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera.
  • On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera.
Yorum Ekle
Now the camera body is loose. gently lift the rear of the case to remove it from the camera. Now the camera body is loose. gently lift the rear of the case to remove it from the camera. Now the camera body is loose. gently lift the rear of the case to remove it from the camera.
  • Now the camera body is loose. gently lift the rear of the case to remove it from the camera.
Yorum Ekle
Next, remove the front of the camera body. Be sure to keep track of the rubber ring. You have now successfully removed the outer case. You have now successfully removed the outer case.
  • Next, remove the front of the camera body. Be sure to keep track of the rubber ring.
  • You have now successfully removed the outer case.
Yorum Ekle
Next, peel the navigation buttons from the button panel and set them aside. To free the LCD display, remove the .113 inch screw in the top left corner. Then, rotate the screen clockwise until it lifts away from the camera.
  • Next, peel the navigation buttons from the button panel and set them aside.
  • To free the LCD display, remove the .113 inch screw in the top left corner.
  • Then, rotate the screen clockwise until it lifts away from the camera.
  • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
Yorum Ekle
To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections. After disconnecting both cables, pull the screen away from the camera to remove it.
  • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
  • After disconnecting both cables, pull the screen away from the camera to remove it.
Yorum Ekle
In order to remove the LCD from its mount, carefully pry up the four tabs along the top and bottom edges of the screen. There is a reflector sheet under the screen that is easily scratched. Try not to touch the reflector as it is nearly impossible to clean. You have now successfully disassembled the LCD.
  • In order to remove the LCD from its mount, carefully pry up the four tabs along the top and bottom edges of the screen.
  • There is a reflector sheet under the screen that is easily scratched. Try not to touch the reflector as it is nearly impossible to clean.
  • You have now successfully disassembled the LCD.
Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Theiss
107 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 18-23, Garner Spring 2011 Cal Poly, Team 18-23, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G23
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 5
Her zaman: 1,868
