Giriş
This guide provides the steps to follow to disassemble the Canon Powershot SD550 down to the main system board. Removal of the main system board is required if the existing board has failed, is in need of cleaning, or requires maintenance.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the 2.9 mm screw in the top left corner.
Rotate the screen clockwise until it lifts away from the camera.
Remove the two 3.4 mm screws still holding the button contact panel onto the camera.
Using the spudger, disconnect the ribbon cable attaching the button contact panel to the motherboard.
Gently pull the button contact panel away from the motherboard.
