Ana içeriğe geç
Canon Powershot SD550 Outer Case Replacement
Neye ihtiyacın var
  1. Canon Powershot SD550 Outer Case Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Outer Case Replacement: adım 2, 1 resimden 1.
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Outer Case Replacement: adım 3, 3 resimden 1. Canon Powershot SD550 Outer Case Replacement: adım 3, 3 resimden 2. Canon Powershot SD550 Outer Case Replacement: adım 3, 3 resimden 3.
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Outer Case Replacement: adım 4, 3 resimden 1. Canon Powershot SD550 Outer Case Replacement: adım 4, 3 resimden 2. Canon Powershot SD550 Outer Case Replacement: adım 4, 3 resimden 3.
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Outer Case Replacement: adım 5, 3 resimden 1. Canon Powershot SD550 Outer Case Replacement: adım 5, 3 resimden 2. Canon Powershot SD550 Outer Case Replacement: adım 5, 3 resimden 3.
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Outer Case Replacement: adım 6, 3 resimden 1. Canon Powershot SD550 Outer Case Replacement: adım 6, 3 resimden 2. Canon Powershot SD550 Outer Case Replacement: adım 6, 3 resimden 3.
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
Sonuç
Matthew Theiss
176 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-23, Garner Spring 2011 Cal Poly, Team 18-23, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G23
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,560
