Ana içeriğe geç
Canon Powershot SD550 Shutter Button Replacement
Neye ihtiyacın var
    1. Canon Powershot SD550 Shutter Button Replacement, Outer Case: adım 1, 1 resimden 1.
      • Remove the battery and SD card from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon Powershot SD550 Shutter Button Replacement: adım 2, 1 resimden 1.
      • Remove the three 3.8 mm screws from the underside of the camera.
      • Each of the screws is slightly different, so it is important that you note the original location of each screw.
      FixBot'a Sor
      Yorum Ekle
    3. Canon Powershot SD550 Shutter Button Replacement: adım 3, 3 resimden 1. Canon Powershot SD550 Shutter Button Replacement: adım 3, 3 resimden 2. Canon Powershot SD550 Shutter Button Replacement: adım 3, 3 resimden 3.
      • Remove the 3.2 mm screw from the right side of the camera.
      • Remove the 2.2 mm screw from the right side of the camera.
      • One of these screws is hidden under the USB port cover.
      • Lift the side panel off.
      • Remove the 1.8 mm screw from underneath the side panel.
      FixBot'a Sor
      Yorum Ekle
    4. Canon Powershot SD550 Shutter Button Replacement: adım 4, 3 resimden 1. Canon Powershot SD550 Shutter Button Replacement: adım 4, 3 resimden 2. Canon Powershot SD550 Shutter Button Replacement: adım 4, 3 resimden 3.
      • Remove the two 2.2 mm screws from the left side of the camera.
      • Lift the plate from the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Canon Powershot SD550 Shutter Button Replacement: adım 5, 3 resimden 1. Canon Powershot SD550 Shutter Button Replacement: adım 5, 3 resimden 2. Canon Powershot SD550 Shutter Button Replacement: adım 5, 3 resimden 3.
      • Gently lift the rear of the case to remove it from the camera.
      FixBot'a Sor
      Yorum Ekle
    6. Canon Powershot SD550 Shutter Button Replacement: adım 6, 3 resimden 1. Canon Powershot SD550 Shutter Button Replacement: adım 6, 3 resimden 2. Canon Powershot SD550 Shutter Button Replacement: adım 6, 3 resimden 3.
      • Remove the front of the camera body.
      • Be sure to keep track of the rubber ring.
      FixBot'a Sor
      Yorum Ekle
    1. Canon Powershot SD550 Shutter Button Replacement, Shutter Button: adım 7, 2 resimden 1. Canon Powershot SD550 Shutter Button Replacement, Shutter Button: adım 7, 2 resimden 2.
      • Next, unscrew the .115 inch screw fastening the shutter button to the camera.
      • Now lift the button away from the camera, exposing the button board.
      • You have successfully removed the shutter button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ken Michael
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-23, Garner Spring 2011 Cal Poly, Team 18-23, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G23
5 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,839
