Giriş
The lens is the device that focuses the image seen by a camera. Because it is the only moving part, it can easily malfunction, causing blurry pictures or even a camera error.
Parçalar
Hiçbir parçaya gerek yok.
In preparation for disassembly, the battery and SD Card need to be removed from the camera. You can access both the battery and the SD card through the door on the bottom of the camera.
Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches.
Remove both screws, then carefully lift the side panel off.
Underneath the side panel, there is a .07 inch screw. Remove it.
Next, peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the .113 inch screw in the top left corner.
Then, rotate the screen clockwise until it lifts away from the camera.
Now the photo sensor is exposed. In order to remove the ribbon cable from its port, first flip up the blue locking mechanism.
After the cable is unlocked, it easily pulls free.
In order to remove the photo sensor, you will have to cut through glue and remove screws.
Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
Now remove the three .15 inch screws holding the photo sensor to the camera frame.
Once the image sensor is removed, turn the camera over and find the screw in the bottom right corner.
Remove this .01 inch screw to free the ribbon cables.
Next, remove the three .12 inch screws that hold the lens assembly to the camera.
2 başka kişi bu kılavuzu tamamladı.
