Ana içeriğe geç
Canon Powershot SD880 Front Cover Replacement
Neye ihtiyacın var
  1. Canon Powershot SD880 Front Cover Replacement, Back Cover: adım 1, 3 resimden 1. Canon Powershot SD880 Front Cover Replacement, Back Cover: adım 1, 3 resimden 2. Canon Powershot SD880 Front Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Front Cover Replacement, Front Cover: adım 2, 3 resimden 1. Canon Powershot SD880 Front Cover Replacement, Front Cover: adım 2, 3 resimden 2. Canon Powershot SD880 Front Cover Replacement, Front Cover: adım 2, 3 resimden 3.
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
Sonuç
Robert Manno
444 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G3
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 2,840
