Ana içeriğe geç
Canon Powershot SD880 LCD Display Replacement
Neye ihtiyacın var
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: adım 1, 3 resimden 1. Canon Powershot SD880 LCD Display Replacement, Back Cover: adım 1, 3 resimden 2. Canon Powershot SD880 LCD Display Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: adım 2, 3 resimden 1. Canon Powershot SD880 LCD Display Replacement, LCD Display: adım 2, 3 resimden 2. Canon Powershot SD880 LCD Display Replacement, LCD Display: adım 2, 3 resimden 3.
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Sonuç
Ben Tupas
317 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G3
5 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 2,340
