Ana içeriğe geç
Canon Powershot SX30 IS Back Camera Housing Replacement
Neye ihtiyacın var
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: adım 1, 2 resimden 1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: adım 1, 2 resimden 2.
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 2, 3 resimden 1. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 2, 3 resimden 2. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 2, 3 resimden 3.
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 3, 2 resimden 1. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 3, 2 resimden 2.
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 4, 1 resimden 1.
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 5, 1 resimden 1.
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 6, 2 resimden 1. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 6, 2 resimden 2.
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 7, 1 resimden 1.
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 8, 1 resimden 1.
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: adım 9, 1 resimden 1.
    • Close the back cover, and re-insert appropriate screws.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ellis DeVoe
580 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015 üyesi
CPSU-MANESS-S15S5G12
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,333
