Neye ihtiyacın var
Turn the camera so the back of it is facing you.
Pull the LCD screen towards you in order to open it,
Use spudger to remove the gold ribbon wire
This is easily done by lifting up the small black lock that holds the ribbon wire in place
Place the wires back on the circut board
The large one can be replaced by placing the wire gently in the slot and then pushing the lock into place
The smaller wire should be fed back into the board using tweezers to prevent bending at the edge.
To finish, follow the previous steps in reverse order to put everything back where it belongs
3 farklı kişi bu kılavuzu tamamladı.
8Kılavuz Yorumları
Great instructions. Took me less time than estimated. Thanks
Thank you. Very clear instructions.
Hi, I just bought a display lcd screen. but it has only one ribbon, not have the little tiny one. What should I do?
Was any body able to find the replacement screen with 2 ribbon cables for the Canon SX30 IS having back light?
If so please share I’m in need of one for my camera.
Thanks
I’m also interested in where to buy the “two ribbon” display version. I just bought the wrong one with one ribbon and recognized that the “one ribbon” version ribbon also is a bit wider than the “two ribbon” version. I guess they changed the design and integrated the two ribbons into one (for assembly purpose I think).
washmann -
The SX10 has 2 ribbons — I wonder if this is a mix up in part numbers?
Where can i buy the lcd ?
how to fix error E40, i can´t reset
