Giriş
User needs PH00 screwdriver, spudger, and plastic pry tool.
Neye ihtiyacın var
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
Bir başkası bu kılavuzu tamamladı.
