Ana içeriğe geç
Canon Powershot SX500 IS LCD Screen Replacement
Neye ihtiyacın var
  1. Canon Powershot SX500 IS LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS LCD Screen Replacement: adım 2, 1 resimden 1.
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS LCD Screen Replacement: adım 3, 1 resimden 1.
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: adım 4, 3 resimden 1. Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: adım 4, 3 resimden 2. Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: adım 4, 3 resimden 3.
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS LCD Screen Replacement: adım 5, 1 resimden 1.
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS LCD Screen Replacement: adım 6, 1 resimden 1.
  7. Canon Powershot SX500 IS LCD Screen Replacement: adım 7, 1 resimden 1.
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS LCD Screen Replacement: adım 8, 2 resimden 1. Canon Powershot SX500 IS LCD Screen Replacement: adım 8, 2 resimden 2.
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS LCD Screen Replacement, Control Dial: adım 9, 1 resimden 1.
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS LCD Screen Replacement: adım 10, 1 resimden 1.
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS LCD Screen Replacement: adım 11, 1 resimden 1.
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS LCD Screen Replacement: adım 12, 1 resimden 1.
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
  13. Canon Powershot SX500 IS LCD Screen Replacement, LCD Screen: adım 13, 1 resimden 1.
    • Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hello, my LCD screen is not working. One day it was fine, the next day I powered my camera and the LCD screen is only half visible. I appreciate the directions on how to take out/repair LCD screen, though where am I able to purchase a new LCD screen for my PowerShot SX500IS? Many thanks.
dana karavias - Yanıt
Disassembly of SX510HS is exactly the same. No special pry tool is required - it is very easy to remove the cover with your fingernail. Replacement LCD on Aliexpress is 8-12 USD.
Witold Kardyś - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 1,213
