Ana içeriğe geç
Canon Rebel T5i SD Card Door Replacement
Neye ihtiyacın var
  1. Canon Rebel T5i SD Card Door Replacement, Back Cover: adım 1, 2 resimden 1. Canon Rebel T5i SD Card Door Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
  2. Canon Rebel T5i SD Card Door Replacement: adım 2, 3 resimden 1. Canon Rebel T5i SD Card Door Replacement: adım 2, 3 resimden 2. Canon Rebel T5i SD Card Door Replacement: adım 2, 3 resimden 3.
    • Peel back the left rubber grip using a plastic opening pick.
    • Underneath the grip, remove the following screws:
    • Four M1.7x5.0mm T6 Torx screws
    • On the right side of the camera, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon Rebel T5i SD Card Door Replacement: adım 3, 2 resimden 1. Canon Rebel T5i SD Card Door Replacement: adım 3, 2 resimden 2.
    • On the bottom of the camera, remove the following screws:
    • One M1.7x6.0mm JIS #000 screw
    • Two M1.7x3.0mm JIS #000 screws
    • On the back of the camera, remove the following screws:
  4. Canon Rebel T5i SD Card Door Replacement: adım 4, 3 resimden 1. Canon Rebel T5i SD Card Door Replacement: adım 4, 3 resimden 2. Canon Rebel T5i SD Card Door Replacement: adım 4, 3 resimden 3.
    • Using a plastic opening pick, partially peel up the top of the back rubber grip.
    • Carefully begin lifting the back cover up away from the camera body.
    • Do not lift it all the way off. There is still a ribbon cable attaching the back cover to the main PCB board.
    • Use a plastic spudger to gently pry off the ribbon cable.
    • Use a plastic spudger to gently pry off the other cable connecting the back cover to the camera.
    • The connector tab sticks out slightly on each end of the connector, which gives you a good spot to pry the connector off.
  5. Canon Rebel T5i SD Card Door Replacement, SD Card Door: adım 5, 2 resimden 1. Canon Rebel T5i SD Card Door Replacement, SD Card Door: adım 5, 2 resimden 2.
    • On the inside of the SD card door, remove the following screws holding the metal plate in place:
    • Two JIS #000 screws
    • Using the end of a screwdriver or another hard tool, push the metal SD card door hinge upwards
    • One the hinge is fully removed, the SD card door can be pulled off the camera.
Sonuç
Ekli Belgeler
Zephosk
4.744 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 47
