Ana içeriğe geç
Canon SX40 HS Camera Battery Door Contact Replacement
Neye ihtiyacın var
  1. Canon SX40 HS Camera Battery Door Contact Replacement, Battery Door Contact: adım 1, 1 resimden 1.
    • Orient the camera so that the bottom of the camera is facing up and open the battery compartment.
  2. Canon SX40 HS Camera Battery Door Contact Replacement: adım 2, 1 resimden 1.
    • Remove the two circled 2mm screws with a Phillips #00 screwdriver.
  3. Canon SX40 HS Camera Battery Door Contact Replacement: adım 3, 1 resimden 1.
    • Slide the metal battery contact away from the battery compartment cover.
  4. Canon SX40 HS Camera Battery Door Contact Replacement: adım 4, 1 resimden 1.
    • Remove the battery compartment cover from the metal bracket.
  5. Canon SX40 HS Camera Battery Door Contact Replacement: adım 5, 1 resimden 1.
    • Replace either the internal metal battery contact or external battery compartment cover.
Sonuç
John Bui
352 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-7, Cichon Spring 2015 UMass Dartmouth, Team 7-7, Cichon Spring 2015 üyesi
UMASSD-CICHON-S15S7G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 909
