Ana içeriğe geç
Canon Selphy CP1200 LCD/Buttons Replacement
Neye ihtiyacın var
  1. Canon Selphy CP1200 LCD/Buttons Replacement, LCD/Buttons: adım 1, 1 resimden 1.
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 LCD/Buttons Replacement: adım 2, 1 resimden 1.
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 LCD/Buttons Replacement: adım 3, 1 resimden 1.
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 LCD/Buttons Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 542
