Giriş
This guide shows how to replace the motherboard of the Canon Selphy CP1200. This replacement may be done to replace a faulty motherboard in the event other components are working, and is a required step for replacing other components including the printing mechanism and cooling fan.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
The top assembly, containing both the LCD and buttons, will now be completely free
I have one but the lcd have Been broken can you give me the number of the lcd please
Detach the fan cable from the motherboard.
Bonjour,
Pourriez vous me dire sur quel site acheter la carte mère de remplacement ?
Merci d'avance
Unscrew the three 3mm PH000 screws from the motherboard.
As at this point the whole printmechanism-motherboard assembly is already loose in the case, you can also consider taking out the whole thing completely before removing these screws. It is much easier to remove the cables at the bottom when you have a bit more space. You have to bend the plastic case a bit so the USB ports are free, but other than that you should have not have a problem.
(do step 10 first though, if possible) -
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Hi, where can I buy a new motherboard for the Selphy CP 1200 online ?
