Ana içeriğe geç
Canon Vixia HF R500 Disassembly
Neye ihtiyacın var
  1. Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: adım 1, 2 resimden 1. Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: adım 1, 2 resimden 2.
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  2. Canon Vixia HF R500 Disassembly: adım 2, 1 resimden 1.
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  3. Canon Vixia HF R500 Disassembly: adım 3, 1 resimden 1.
    • Remove the side piece plate.
  4. Canon Vixia HF R500 Disassembly: adım 4, 1 resimden 1.
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  5. Canon Vixia HF R500 Disassembly: adım 5, 1 resimden 1.
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  6. Canon Vixia HF R500 Disassembly: adım 6, 1 resimden 1.
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  7. Canon Vixia HF R500 Disassembly: adım 7, 3 resimden 1. Canon Vixia HF R500 Disassembly: adım 7, 3 resimden 2. Canon Vixia HF R500 Disassembly: adım 7, 3 resimden 3.
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  8. Canon Vixia HF R500 Disassembly: adım 8, 1 resimden 1.
    • Remove the top piece.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 747
