Ana içeriğe geç
Canon Vixia HF R500 Zoom Control Replacement
Neye ihtiyacın var
  1. Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: adım 1, 3 resimden 1. Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: adım 1, 3 resimden 2. Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: adım 1, 3 resimden 3.
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Zoom Control  Replacement, Battery: adım 2, 1 resimden 1.
    • Hold on to the battery.
  3. Canon Vixia HF R500 Zoom Control  Replacement: adım 3, 1 resimden 1.
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Zoom Control  Replacement: adım 4, 1 resimden 1.
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: adım 5, 2 resimden 1. Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: adım 5, 2 resimden 2.
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Zoom Control  Replacement: adım 6, 1 resimden 1.
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Zoom Control  Replacement: adım 7, 1 resimden 1.
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Zoom Control  Replacement: adım 8, 1 resimden 1.
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Zoom Control  Replacement: adım 9, 1 resimden 1.
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Zoom Control  Replacement: adım 10, 1 resimden 1.
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Zoom Control  Replacement: adım 11, 3 resimden 1. Canon Vixia HF R500 Zoom Control  Replacement: adım 11, 3 resimden 2. Canon Vixia HF R500 Zoom Control  Replacement: adım 11, 3 resimden 3.
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Zoom Control  Replacement: adım 12, 1 resimden 1.
    • Remove the top piece.
  13. Canon Vixia HF R500 Zoom Control  Replacement, Speaker: adım 13, 2 resimden 1. Canon Vixia HF R500 Zoom Control  Replacement, Speaker: adım 13, 2 resimden 2.
    • Remove the three 6mm Philips #000 screws holding the black record piece.
  14. Canon Vixia HF R500 Zoom Control  Replacement: adım 14, 1 resimden 1.
    • Remove the black record piece.
  15. Canon Vixia HF R500 Zoom Control  Replacement: adım 15, 2 resimden 1. Canon Vixia HF R500 Zoom Control  Replacement: adım 15, 2 resimden 2.
    • Holding the full top piece remove the six 5mm Philips #000 screws holding the metal frame to the top piece.
  16. Canon Vixia HF R500 Zoom Control  Replacement: adım 16, 1 resimden 1.
    • Carefully remove the the whole metal frame out of the device piece.
  17. Canon Vixia HF R500 Zoom Control  Replacement: adım 17, 1 resimden 1.
    • Replace the defective speaker with a functioning one.
  18. Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: adım 18, 2 resimden 1. Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: adım 18, 2 resimden 2.
    • Examine the grey zoom input tab located on copper plate.
    • Examine the black plastic zoom slider, on the top cover of the camera
    • Repair or replace damaged components and clear all debris from mechanisms.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 280
