Ana içeriğe geç
Canon Vixia HF R600 LCD screen Replacement
Neye ihtiyacın var
  1. Canon Vixia HF R600 LCD screen Replacement, Handstrap: adım 1, 2 resimden 1. Canon Vixia HF R600 LCD screen Replacement, Handstrap: adım 1, 2 resimden 2.
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 LCD screen Replacement: adım 2, 2 resimden 1. Canon Vixia HF R600 LCD screen Replacement: adım 2, 2 resimden 2.
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 LCD screen Replacement, Battery: adım 3, 2 resimden 1. Canon Vixia HF R600 LCD screen Replacement, Battery: adım 3, 2 resimden 2.
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 LCD screen Replacement, Casing: adım 4, 2 resimden 1. Canon Vixia HF R600 LCD screen Replacement, Casing: adım 4, 2 resimden 2.
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 LCD screen Replacement: adım 5, 2 resimden 1. Canon Vixia HF R600 LCD screen Replacement: adım 5, 2 resimden 2.
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 LCD screen Replacement: adım 6, 2 resimden 1. Canon Vixia HF R600 LCD screen Replacement: adım 6, 2 resimden 2.
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 LCD screen Replacement, LCD Screen: adım 7, 1 resimden 1.
    • Remove the LCD display from the camera body.
  8. Canon Vixia HF R600 LCD screen Replacement: adım 8, 3 resimden 1. Canon Vixia HF R600 LCD screen Replacement: adım 8, 3 resimden 2. Canon Vixia HF R600 LCD screen Replacement: adım 8, 3 resimden 3.
    • Rotate the display hinge to reveal two 4mm Phillips #00 screws.
    • Before removing, use the plastic opening tool to pry apart the plastic hinge cover.
    • Remove the cover.
  9. Canon Vixia HF R600 LCD screen Replacement: adım 9, 3 resimden 1. Canon Vixia HF R600 LCD screen Replacement: adım 9, 3 resimden 2. Canon Vixia HF R600 LCD screen Replacement: adım 9, 3 resimden 3.
    • Remove the two 4mm Phillips #00 screws.
    • Pull the LCD display back cover to reveal the motherboard covering the screen.
    • Remove one more 4mm Phillips #00 screw.
  10. Canon Vixia HF R600 LCD screen Replacement: adım 10, 3 resimden 1. Canon Vixia HF R600 LCD screen Replacement: adım 10, 3 resimden 2. Canon Vixia HF R600 LCD screen Replacement: adım 10, 3 resimden 3.
    • Pull the screen protector away from the LCD display.
    • Use a plastic opening tool to lift the ribbon connector tab.
    • The LCD display can now be replaced!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian Luna
483 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Lacy Spring 2016 USF Tampa, Team 14-4, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G4
3 Üyeler
16 adet Kılavuz yazıldı
6 Yorum
Where did you find the replacement LCD screen at? Specifically I am looking for the Vixia HF M41A version
Jeff Onsrud - Yanıt
I can’t find the replacement lcd for my model canon vixia hf R600, can you point me in the right direction?
Seth Flake - Yanıt
Gotta hf r800 and need screen, any ideas where?
Sean - Yanıt
Very nice step by step guidance. Where can I find the Replacement lcd screen for Canon Vixia HFR 600 camera. Will appreciate that!
Thanks!
shelaindrab - Yanıt
I have a Canon Vixia HF R52, and with all my research it looks like all of these are the same LCD: HF-R52, HF-R82, HF-R600.....and maybe even the HF-R48, and HF-R406, and HF-R706.
pe.labs - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 2,295
