Giriş
If the power button is unresponsive or stuck, it may need to be cleaned or replaced. This guide will help you remove the button from the camera body.
Neye ihtiyacın var
Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
To remove the hand-strap, pull the Velcro strip through the leather pad.
Press in the battery release tab located on the bottom of the camera.
Slide the battery out from the body.
Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
Remove one 4mm Phillips JIS#00 screw on the right side of the camera.
Use the plastic opening tool to undo the bronze ribbon connector.
