Ana içeriğe geç
Canon Vixia HF R600 Speaker Replacement
Neye ihtiyacın var
  1. Canon Vixia HF R600 Speaker Replacement, Handstrap: adım 1, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement, Handstrap: adım 1, 2 resimden 2.
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Speaker Replacement: adım 2, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Speaker Replacement, Battery: adım 3, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement, Battery: adım 3, 2 resimden 2.
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Speaker Replacement, Casing: adım 4, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement, Casing: adım 4, 2 resimden 2.
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Speaker Replacement: adım 5, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement: adım 5, 2 resimden 2.
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Speaker Replacement: adım 6, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement: adım 6, 2 resimden 2.
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Speaker Replacement, Speaker: adım 7, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Remove one 4mm Phillips JIS#00 screw on the right side of the camera.
    • Use the plastic opening tool to undo the bronze ribbon connector.
  8. Canon Vixia HF R600 Speaker Replacement: adım 8, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement: adım 8, 2 resimden 2.
    • Remove one 4mm Phillips JIS#00 screw located on the top of the camera near the battery connection.
    • Pull the plastic casing away from the camera. The speaker and power button are housed in this casing.
  9. Canon Vixia HF R600 Speaker Replacement: adım 9, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement: adım 9, 2 resimden 2.
    • Remove four 5mm Phillips PH#00 screws holding the speaker bracket in place.
    • Remove one more 5mm screw below the power button.
  10. Canon Vixia HF R600 Speaker Replacement: adım 10, 2 resimden 1. Canon Vixia HF R600 Speaker Replacement: adım 10, 2 resimden 2.
    • Carefully pull the speaker out of the casing.
Sonuç
Logan Coats
522 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Lacy Spring 2016 USF Tampa, Team 14-4, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G4
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 288
