Giriş
Use this guide to remove and replace the shutter to your Canon Vixia HF R70.
Neye ihtiyacın var
Power off and unplug the device.
Position the camera so that the battery is facing you.
Position the camcorder so that the wrist strap is facing you.
Locate the loose end of the strap.
Position the camcorder so that the side panel is facing you.
Locate the two 6mm Phillips #00 screws on the side panel.
Remove the the screws using a screwdriver with a Phillips #00 head.
Disconnect the wires by inserting the plastic opening tool into the small slit.
Begin to push upward with the plastic opening tool, disconnecting the two compartments.
There are three 5mm Phillips #00 screws that need to be removed - one on the top, one on the side, and one on the bottom.
Locate and remove the screw on the top side of the camera.
Locate and remove the screw on the side of the camera where you previously removed the side panel.
Locate and remove the screw on the bottom of the camera.
