Ana içeriğe geç
Canon Vixia HF R70 Top Panel Replacement
Neye ihtiyacın var
  1. Canon Vixia HF R70 Top Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Power off and unplug the device.
    • Position the camera so that the battery is facing you.
  2. Canon Vixia HF R70 Top Panel Replacement: adım 2, 1 resimden 1.
    • Locate the latch on the bottom edge of the camera.
    • Hold the battery into place and gently push down on the latch towards the lens.
  3. Canon Vixia HF R70 Top Panel Replacement: adım 3, 2 resimden 1. Canon Vixia HF R70 Top Panel Replacement: adım 3, 2 resimden 2.
    • While holding down the latch, remove the battery by pulling it out of the device.
  4. Canon Vixia HF R70 Top Panel Replacement, Wrist Strap: adım 4, 1 resimden 1.
    • Position the camcorder so that the wrist strap is facing you.
    • Locate the loose end of the strap.
  5. Canon Vixia HF R70 Top Panel Replacement: adım 5, 1 resimden 1.
    • Gently pull on the loose end to separate the Velcro.
  6. Canon Vixia HF R70 Top Panel Replacement: adım 6, 1 resimden 1.
    • Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
    • Pull the strap through the loop.
  7. Canon Vixia HF R70 Top Panel Replacement: adım 7, 2 resimden 1. Canon Vixia HF R70 Top Panel Replacement: adım 7, 2 resimden 2.
    • Pull the strap through the leather cushion.
  8. Canon Vixia HF R70 Top Panel Replacement: adım 8, 1 resimden 1.
    • Pull the strap through the slot on the left side of the camcorder.
  9. Canon Vixia HF R70 Top Panel Replacement, Side Panel: adım 9, 2 resimden 1. Canon Vixia HF R70 Top Panel Replacement, Side Panel: adım 9, 2 resimden 2.
    • Position the camcorder so that the side panel is facing you.
    • Locate the two 6mm Phillips #00 screws on the side panel.
    • Remove the the screws using a screwdriver with a Phillips #00 head.
  10. Canon Vixia HF R70 Top Panel Replacement: adım 10, 3 resimden 1. Canon Vixia HF R70 Top Panel Replacement: adım 10, 3 resimden 2. Canon Vixia HF R70 Top Panel Replacement: adım 10, 3 resimden 3.
    • Turn the camcorder so that the bottom is facing you.
    • Using your screwdriver, locate and remove the four 6mm Phillips #00 screws connecting the side panel to the bottom of the camcorder.
  11. Canon Vixia HF R70 Top Panel Replacement: adım 11, 2 resimden 1. Canon Vixia HF R70 Top Panel Replacement: adım 11, 2 resimden 2.
    • Gently remove the side panel by pushing it up from the bottom.
  12. Canon Vixia HF R70 Top Panel Replacement, Top Panel: adım 12, 2 resimden 1. Canon Vixia HF R70 Top Panel Replacement, Top Panel: adım 12, 2 resimden 2.
    • Disconnect the wires by inserting the plastic opening tool into the small slit.
    • Begin to push upward with the plastic opening tool, disconnecting the two compartments.
  13. Canon Vixia HF R70 Top Panel Replacement: adım 13, 3 resimden 1. Canon Vixia HF R70 Top Panel Replacement: adım 13, 3 resimden 2. Canon Vixia HF R70 Top Panel Replacement: adım 13, 3 resimden 3.
    • Disconnect the four ZIF connectors by grasping the connector firmly and pulling gently.
  14. Canon Vixia HF R70 Top Panel Replacement: adım 14, 1 resimden 1.
    • Locate and remove the two 3mm Phillips #00 screws on the side of the camera where the side panel was removed.
  15. Canon Vixia HF R70 Top Panel Replacement: adım 15, 1 resimden 1.
    • Turn the camera over to the side with the LCD screen, and open the screen.
    • Locate and remove the three 5mm Phillips #00 screws holding the top panel in place.
  16. Canon Vixia HF R70 Top Panel Replacement: adım 16, 3 resimden 1. Canon Vixia HF R70 Top Panel Replacement: adım 16, 3 resimden 2. Canon Vixia HF R70 Top Panel Replacement: adım 16, 3 resimden 3.
    • Pull the panel up and away until it is removed completely.
Sonuç
Thomas Rogienski
501 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Nance Spring 2017 USF Tampa, Team S2-G2, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G2
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 200
