Ana içeriğe geç
Canon Vixia HF S10 Camcorder Audio Replacement
Neye ihtiyacın var
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: adım 1, 3 resimden 1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: adım 1, 3 resimden 2. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: adım 1, 3 resimden 3.
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: adım 2, 3 resimden 1. Canon Vixia HF S10 Camcorder Audio Replacement: adım 2, 3 resimden 2. Canon Vixia HF S10 Camcorder Audio Replacement: adım 2, 3 resimden 3.
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: adım 3, 3 resimden 1. Canon Vixia HF S10 Camcorder Audio Replacement: adım 3, 3 resimden 2. Canon Vixia HF S10 Camcorder Audio Replacement: adım 3, 3 resimden 3.
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
Sonuç
Clint
101 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 420
