Ana içeriğe geç
Canon ZR70MC Speaker Replacement
Neye ihtiyacın var
  1. Canon ZR70MC Speaker Replacement, Front Panel: adım 1, 2 resimden 1. Canon ZR70MC Speaker Replacement, Front Panel: adım 1, 2 resimden 2.
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Speaker Replacement: adım 2, 1 resimden 1.
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Speaker Replacement: adım 3, 3 resimden 1. Canon ZR70MC Speaker Replacement: adım 3, 3 resimden 2. Canon ZR70MC Speaker Replacement: adım 3, 3 resimden 3.
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Speaker Replacement: adım 4, 3 resimden 1. Canon ZR70MC Speaker Replacement: adım 4, 3 resimden 2. Canon ZR70MC Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Speaker Replacement: adım 5, 2 resimden 1. Canon ZR70MC Speaker Replacement: adım 5, 2 resimden 2.
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Speaker Replacement: adım 6, 3 resimden 1. Canon ZR70MC Speaker Replacement: adım 6, 3 resimden 2. Canon ZR70MC Speaker Replacement: adım 6, 3 resimden 3.
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Speaker Replacement: adım 7, 3 resimden 1. Canon ZR70MC Speaker Replacement: adım 7, 3 resimden 2. Canon ZR70MC Speaker Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
  8. Canon ZR70MC Speaker Replacement, Speaker: adım 8, 3 resimden 1. Canon ZR70MC Speaker Replacement, Speaker: adım 8, 3 resimden 2. Canon ZR70MC Speaker Replacement, Speaker: adım 8, 3 resimden 3.
    • Take the front panel and remove the three 2.75 mm screws from the metal plate.
  9. Canon ZR70MC Speaker Replacement: adım 9, 3 resimden 1. Canon ZR70MC Speaker Replacement: adım 9, 3 resimden 2. Canon ZR70MC Speaker Replacement: adım 9, 3 resimden 3.
    • Remove the metal plate. This metal plate protects the black speaker holder.
  10. Canon ZR70MC Speaker Replacement: adım 10, 3 resimden 1. Canon ZR70MC Speaker Replacement: adım 10, 3 resimden 2. Canon ZR70MC Speaker Replacement: adım 10, 3 resimden 3.
    • Remove the black speaker holder from the front panel. This holds the individual speakers.
  11. Canon ZR70MC Speaker Replacement: adım 11, 3 resimden 1. Canon ZR70MC Speaker Replacement: adım 11, 3 resimden 2. Canon ZR70MC Speaker Replacement: adım 11, 3 resimden 3.
    • Remove the individual speakers from the black speaker holder.
Sonuç
khalid clarke
824 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G2, Boczar Fall 2017 USF Tampa, Team S13-G2, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S13G2
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 142
